20 years agoavalon slave interface
Hi All, I'm a new, i'm trying to make an avalon slave interface to have access to an external logic ( Fifo), i would just write, read and controls the fifo from the nios. i didn't f...
20 years agoThe document you should read is the Avalon Interface Specification
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) and the Developing Components for SOPC Builder http://www.altera.com/literature/hb/qts/qts_qii54007.pdf (http://www.altera.com/literature/hb/qts/qts_qii54007.pdf) Those should get you started. Can't just give you the answers you know. Play around and then post some specific questions if you get stuck. Jake
