13 years ago
Auto-Negotiation FAILED
I have a custom board with the 88E111 Ethernet PHY. At one point, the board would light up LEDs indicating a link has been made and it was in 100 mode.
I did not change my design at all, but now I can't make a link. This first happened when I tried to plug the board directly into the LAN from the wall, rather than through the switch, in an attempt to get DHCP to work. I now have the board connected to a switch which goes to a PC and company LAN.
The lights on the switch indicate that there is a physical connection made on the port the board is plugged into. They blink with 10 mode activity. But, the board doesn't indicate a link.
Running the simple socket server design produces this output:
prepped 1 interface, initializing...
INFO    : TSE MAC 0 found at address 0x08000000
INFO    : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group
INFO    : PHY - Automatically mapped to tse_mac_device
INFO    : PHY - Restart Auto-Negotiation, checking PHY link...
WARNING : PHY - Auto-Negotiation FAILED
MARVELL : Enabling auto crossover
MARVELL : PHY reset
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO    : PHY - Checking link...
INFO    : PHY - Link not yet established, restart auto-negotiation...
WARNING : PHY - Link could not established
WARNING : PHY - Auto-Negotiation not completed! Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
I am completely stumped on how I can't even make a link now, without changing any hardware or software.
Before moving cables to plug the board directly into the wall, it would pass the auto negotiation and then fail at DHCP. I have gone back to the original setup exactly but the result is the same. No link at all.
    But I use quartus 14.0. Also appear this messge. Have you fiugred it out?
    --- Quote Start ---
    I seem to have fixed the problem, hopefully permanently, by adding a 100 clock cycle delay til I drive the ethernet PHY reset line high when the board powers up.
    --- Quote End ---
    I am facing exactly the same error. Could you tell me steps that how you added 100 clock cycle delay to resolve this issue. I am using Quartus 15.1 and Altera DE2-115 board.
  • APaga1's avatar
    APaga1
    I have got the same issue. I am getting the following error :
    InterNiche Portable TCP/IP, v3.1
    Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
    altera_eth_tse_init 0
    prep_tse_mac 0
    Your Ethernet MAC address is 00:07:ed:ff:e2:d0
    Static IP Address is 192.168.1.234
    tse_mac_init 0
    List of PHY profiles supported (Total profiles = 5)...
    Profile No. 0 :
    PHY Name : Marvell 88E1111
    PHY OUI : 0x005043
    PHY Model Num. : 0x0c
    PHY Rev. Num. : 0x02
    Status Register : 0x11
    Speed Bit : 14
    Duplex Bit : 13
    Link Bit : 10
    Profile No. 1 :
    PHY Name : Marvell Quad PHY 88E1145
    PHY OUI : 0x005043
    PHY Model Num. : 0x0d
    Speed Bit : 14
    Duplex Bit : 13
    Link Bit : 10
    Profile No. 2 :
    PHY Name : National DP83865
    PHY OUI : 0x080017
    PHY Model Num. : 0x07
    PHY Rev. Num. : 0x0a
    Speed Bit : 3
    Duplex Bit : 1
    Link Bit : 2
    Profile No. 3 :
    PHY Name : National DP83848C
    PHY OUI : 0x080017
    PHY Model Num. : 0x09
    PHY Rev. Num. : 0x00
    Status Register : 0x00
    Speed Bit : 0
    Duplex Bit : 0
    Link Bit : 0
    Profile No. 4 :
    PHY Name : Intel PEF7071
    PHY OUI : 0x355969
    PHY Model Num. : 0x00
    PHY Rev. Num. : 0x01
    Speed Bit : 0
    Duplex Bit : 0
    Link Bit : 0
    INFO : TSE MAC 0 found at address 0x08000800
    INFO : Multi Channel = No
    INFO : MDIO Shared = No
    INFO : MAC Type = 10/100/1000 Ethernet MAC
    INFO : MAC Address = 0x08000800
    INFO : MAC Device = tse_mac_device[0]
    INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
    INFO : PHY OUI = 0x005043
    INFO : PHY Model Number = 0x0c
    INFO : PHY Revision Number = 0x2
    INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
    INFO : PHY[0.0] - Advertisement of 1000 Base-T Full Duplex set to 1
    INFO : PHY[0.0] - Advertisement of 1000 Base-T Half Duplex set to 1
    INFO : PHY[0.0] - Advertisement of 100 Base-T4 set to 0
    Created "Inet main" task (Prio: 2)
    INFO : PHY[0.0] - Advertisement of 100 Base-TX Full Duplex set to 1
    INFO : PHY[0.0] - Advertisement of 100 Base-TX Half Duplex set to 1
    INFO : PHY[0.0] - Advertisement of 10 Base-TX Full Duplex set to 1
    INFO : PHY[0.0] - Advertisement of 10 Base-TX Half Duplex set to 1
    INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
    INFO : PHY[0.0] - Auto-Negotiation PASSED
    INFO : Applying additional PHY configuration of Marvell 88E1111
    INFO : Applying additional user PHY configuration
    MARVELL : PHY reset
    INFO : PHY[0.0] - Checking link...
    INFO : PHY[0.0] - Link not yet established, restart auto-negotiation...
    WARNING : PHY[0.0] - Auto-Negotiation FAILED
    I have been trying to implement Nios II simple socket server from the reference design : https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/nios-ii-simple-socket-server-ethernet-example-for-cvgt/
    I was able to setup everything and start downloading the Nios II software project to the board. But while doing so, I am facing this auto negotiation failed warning. i am unable to decide whether the connection to the board was established or not. I have disabled the DHCP and given the address 192.168.1.234 in the simple_socket_server.h file. I have been following the steps mentioned in the document : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_nios2_tcpip.pdf
    Previosly i have implemented CVGT Simple_Socket_Server from the document https://www.intel.com/content/dam/altera-www/global/en_US/uploads/9/97/CVGT_Simple_Socket_Server_Design_Example.pdf where I have used the static IP for TCP/IPv4 with the IP address 192.168.1.1 . It worked fine. Kindly help me with the Auto negotiation error . I have uploaded the relevant screenshots in the NIOS II SBT. Thank You.
  • APaga1's avatar
    APaga1
    --- Quote Start ---
    --- Quote End ---
    I am facing the same issue. Can you elaborate where should we add 100 clock cycle delay?
    • christnp's avatar
      christnp
      Any luck resolving this?
      I had this working on DE2-115 board with the SSS example using Quartus 17.0 and SGDMA; however, upgrading to Quartus 17.1 and now NIOS II SBT BSP requires the mSGDMA module. So I've migrated to mSGDMA... everything builds and runs just fine, but now auto-negotiaton fails.
