16 years ago
assembly language in the nios ii ide
Hi
does the nios ii ide support assemble language?
why does my assemble codes occur errors?
my setup project proceed as follows:
1 Start the Nios II IDE. (Start->All Programs->Altera->NiosII EDS 9-> NiosII
9 IDE
2 Creat a new project. File->New->Project Nios II C/C++ Application
3 Select blankproject from templates
4 Set the project name
5 Select the target hardware( sopc builder system has been setup)
6 Click Next
7 Click New system libary
8 Click Finish
9 Add a file with name basics.s (File->New->Other
This opens a popup where you can pick File from under the General
Category, after selecting File, you need to specify the name at the bottom
(use basics.s)
10 enter the code:
.include"nios_macros.s"
.text
.equ TEST_NUM,0x90abcdef
.global _start
_start:
movia r7,TEST_NUM
mov r4,r7
STRING_COUNTER:
mov r2,r0
STRING_COUNTER_LOOP:
beq r4,r0,END_STRING_COUNTER
srli r5,r4,1
and r4,r4,r5
addi r2,r2,1
br STRING_COUNTER_LOOP
END_STRING_COUNTER:
mov r16,r2
END:
br END
.end
11 Use Debug As -> Nios II Instruction Set Simulator which will build the
project (assemble the file) and start the debugger.
then errors occur
errors: /cygdrive/d/altera/90/nios2eds/components/altera_hal/HAL/src/alt_main.c undefined reference to `main'
/cygdrive/d/altera/90/quartus/FPGA_code/computer_organization/lab_ex1/part1_1/software/asm_first_syslib/Debug/crt0.o(.text+0x0):/cygdrive/d/altera/90/ip/altera/nios2_ip/altera_nios2/HAL/src/crt0.S first defined here
/cygdrive/d/altera/90/quartus/FPGA_code/computer_organization/lab_ex1/part1_1/software/asm_first_syslib/Debug/libasm_first_syslib.a(alt_main.o) In function `alt_main':
Can't open nios_macros.s for reading: No such file or directory
obj/part2.o In function `_start':
Warning: end of file not at end of a line; newline inserted
ps:
1 i'm sure the codes are right(de2-70 labs exercises/computer organization/lab1)
2 the operator proceed is from duke.edu by google
forgive my ugly English,:D.
Best regards
hanshaohua
