16 years agoassembly language in the nios ii ide
Hi does the nios ii ide support assemble language? why does my assemble codes occur errors? my setup project proceed as follows: 1 Start the Nios II IDE. (Start->All Programs->Altera->...
16 years agoFinally, the problem is solved.
1 assembly file is xx.S,not xx.s 2 You must have a function or label called main. If main is written in assembly-language, the label main must be declared global with the .global directive. 3 Project default in Eclipse woring dir would be best. Thank you ,Bill,Kevin.
