16 years agoassembly language in the nios ii ide
Hi does the nios ii ide support assemble language? why does my assemble codes occur errors? my setup project proceed as follows: 1 Start the Nios II IDE. (Start->All Programs->Altera->...
16 years ago --- Quote Start --- Have you tried _main instead of _alt_main? --- Quote End --- yes,have the same errors. If there is something wrong with the code, i can continue to work on labs exercises. But,if nios ii does not support assembly code , i have no idea how to go on. May be i can try nios ii command shell( i'm familiar with linux and know of many commands). :) Thanks all the same. hanshaohua
