16 years agoApp only works under debug
I've come across an interesting problem - I've generated a NIOS II/f core with some basic peripherals such as three PIOs for the toggle switches, red LEDs and 7-segment displays on the DE2-70 board. ...
16 years agoIn your case it may be easiest to arrange that the PIO addresses have the MSB set. ie are between 0x80000000 and 0x8fffffff.
That will let you use normal C accesses instead if obfustacting the code with macros.
