16 years agoApp only works under debug
I've come across an interesting problem - I've generated a NIOS II/f core with some basic peripherals such as three PIOs for the toggle switches, red LEDs and 7-segment displays on the DE2-70 board. ...
16 years ago --- Quote Start --- I found the easiest way to solve this problem is to use the IORD_... and IOWR_... commands. --- Quote End --- That's what I usually use, but I was trying for a "quick and dirty" solution, and was intrigued when it didn't work. I'd always worked with the slower cores and my pointer solution worked, so I had an "Ahha" moment when I figured out the problem (and the need for the IORD/IOWR functions).
