16 years agoApp only works under debug
I've come across an interesting problem - I've generated a NIOS II/f core with some basic peripherals such as three PIOs for the toggle switches, red LEDs and 7-segment displays on the DE2-70 board. ...
16 years agoYou know I spent about 2 or 3 hours trying to figure out why this wouldn't work for me until I realized the 'f' core has a data cache. The HAL Macros always worked fine but I was just doing an:
*pio_out_ptr = *pio_in_ptr; There is also an instruction that will flush a cache line, however I'm not familiar enough with mixing ASM and C to tell you how to properly save any registers you would need to the stack. I'm sure a few minutes looking at the disassembly would solve that though.
