16 years agoApp only works under debug
I've come across an interesting problem - I've generated a NIOS II/f core with some basic peripherals such as three PIOs for the toggle switches, red LEDs and 7-segment displays on the DE2-70 board. ...
16 years agoEither get the compiler to generate 'ldio' or 'stio' instructions, or set the 2^31 bit on the addresses.
Or disable the data cache! and (probably) put all your program data in tightly coupled memory.
