20 years agoAnyone else using the Stratix II DSP Kit?
Hi all, I have a Stratix II DSP kit that I will use to test out some DSP algorithms. However, first I want to boot a NIOS processor and get the simple socket server test running. I want to be able to transfer the results of a test over ethernet to a control computer.
The DSP kit does not ship with a 'standard' reference design, so it looks like I'll have to start with the NIOS II/Stratix II development kit reference design, and adjust pin assignments. The DSP kit ships with a 100MHz clock, so I figure I'll use the PLL to reduce it to 50MHz. Anyone else already dealt with these issues? Regards, Dave Hawkins. Caltech.2 Replies
Hello Dave,
Which version of CD do you have with your DSP kit? On StratixII_DSP_Kit-v1.1.0 CD I have all reference designs: fast, full_featured, small, and standard. Maybe you should upgrade your software. I also just sturted playing with this kit. My idea is to test my cores in FPGA and present the test results on www. Regards, - Altera_Forum
I am using StratixII-ep2s60-dsp-development-board. this board is now communicating with vcc++-program over tcp/ip. nios2 program size is too large(380KB), so it is located in cfi-flash memory. (i need on-chip memory to design image-processing-ip) if you have the same problem, you should make the flash_writer_circuit to download program into flash, and also you should make "target board" to create actual nios2-cpu. flash boot address is: factory: 0x200000 user1 : 0x500000 user2 : 0x800000 user3 : 0xc00000
