20 years agoAnyone else using the Stratix II DSP Kit?
Hi all, I have a Stratix II DSP kit that I will use to test out some DSP algorithms. However, first I want to boot a NIOS processor and get the simple socket server test running. I want to be able to...
20 years agoHi,
I am using StratixII-ep2s60-dsp-development-board. this board is now communicating with vcc++-program over tcp/ip. nios2 program size is too large(380KB), so it is located in cfi-flash memory. (i need on-chip memory to design image-processing-ip) if you have the same problem, you should make the flash_writer_circuit to download program into flash, and also you should make "target board" to create actual nios2-cpu. flash boot address is: factory: 0x200000 user1 : 0x500000 user2 : 0x800000 user3 : 0xc00000
