20 years agoAN371 Automotive Graphics System Application Note
as title..it's Altera reference design
when I fade in the picture,there is some green mask to cover the picture.. is anyone have use this reference design !? how can I cancel this reset background(change to black)?2 Replies
Yes i'ts realy is.
The problem in LAncelot board, not in project. You can solve it in 2 ways 1. Just use TFT monitor http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ) 2. Look at the schematic of Lancelot board - need to set or clear some input at video DAC (i don't know exactly what need to fix in Lancelot because i make my own Lancelot- like board where i do correct connection to videodac) Be sure - i check this to many times - so you don't need to change vga timings !! The problem is only videodac using in lancelot board. --- Quote Start --- originally posted by suway1219@Apr 8 2006, 01:17 AM as title..it's altera reference designwhen i fade in the picture,there is some green mask to cover the picture..
how can i cancel this reset background(change to black)?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14141)
--- quote end ---
--- Quote End ---
--- Quote Start --- originally posted by alexs@Apr 9 2006, 12:20 PM yes i'ts realy is.the problem in lancelot board, not in project.
you can solve it in 2 ways
1. just use tft monitor http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif )
2. look at the schematic of lancelot board - need to set or clear some input at video dac
(i don't know exactly what need to fix in lancelot because i make my own lancelot-
be sure - i check this to many times - so you don't need to change vga timings !!
the problem is only videodac using in lancelot board.
--- quote start ---
originally posted by suway1219@apr 8 2006, 01:17 am
as title..it's Altera reference design when I fade in the picture,there is some green mask to cover the picture.. is anyone have use this reference design !? how can I cancel this reset background(change to black)? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14141) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14174)</div> [/b] --- Quote End --- Thanks a lot. I have solved this problem.
