20 years agoAN371 Automotive Graphics System Application Note
as title..it's Altera reference design when I fade in the picture,there is some green mask to cover the picture.. is anyone have use this reference design !? how can I cancel this...
20 years ago --- Quote Start --- originally posted by alexs@Apr 9 2006, 12:20 PM yes i'ts realy is.
the problem in lancelot board, not in project.
you can solve it in 2 ways
1. just use tft monitor http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif )
2. look at the schematic of lancelot board - need to set or clear some input at video dac
(i don't know exactly what need to fix in lancelot because i make my own lancelot-
like board where i do correct connection to videodac)
be sure - i check this to many times - so you don't need to change vga timings !!
the problem is only videodac using in lancelot board.
--- quote start ---
originally posted by suway1219@apr 8 2006, 01:17 am
as title..it's Altera reference design when I fade in the picture,there is some green mask to cover the picture.. is anyone have use this reference design !? how can I cancel this reset background(change to black)? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14141) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14174)</div> [/b] --- Quote End --- Thanks a lot. I have solved this problem.
