ALTPLL Megawizard crashes
I have an ALTPLL in my design.
When I try to change it, the Megawizard gets to the 2nd screen, then stops responding to input. After a while, a pop-up comes along and says that it's not responding, and offers to kill it for me. And, near as I can tell, the configuration is now whacked. This is Quartus-15.0 WebPack on Linux (CentOS 7)21 Replies
--- Quote Start --- It sounds like you are instantiating PLLs inside of QSYS. I don’t have too much experience with that as I typically instantiate them at the top level with the standalone qmegawiz command line application. It is started from the ip catalog in recent versions of the quartus GUI. One definitely needs to be diligent to expand the window first before touching any other part of the PLL GUI, to avoid the 100% of the CPU core lock-up. Jeff --- Quote End --- Jeff, Yes, the ALTLL megawizard is Qsys function. It is hard to re-size a screen that is displayed for less than a second. Thanks for helping - - Altera_Forum
Did you free up some memory resources before loading the PLL in Qsys? Or you can try increasing the required memory setting in Settings>IP Settings>Max Qsys memory usage> 1GB. By default, it is set to 500MB.
As of August 20, 2015 and Quartus 15 Service Pack 2, it is still broken.
I confirm this problem on 64-bit linux both fedora and ubuntu with Quartus 15.0. Works on Windows though.
On Linux, I changed the window manager to metacity and used gnome-tweak-tool to try different combinations of themes and disabling effects. Now the megawizard finishes but does not produce any output into Qsys. This is very annoying. - Altera_Forum
OK The megawizard ALTPLL plugin works from OUTSIDE Qsys but not INSIDE. I think this is some bad message going on between the two.
- TJorg2
Still a problem in 19.1 under Ubuntu but resizing the window works for me.
- AHoch4
Ubuntu 18.04LTS, same as TJorg2... Wizard is still not working but with fast enough resizing, the whole system "just" gets very slow and lagging but the wizard is working.
- EagleRay
I can confirm that after 5 years, this is still a problem. As suggested above I agree that a solid command line interface or just simple text based configuration files would be more helpful than a dysfunctional wizard.
- dvirc
looks like a tcl script issue is causing that and can be fixes easily
