11 years agoALTPLL Megawizard crashes
I have an ALTPLL in my design. When I try to change it, the Megawizard gets to the 2nd screen, then stops responding to input. After a while, a pop-up comes along and says that it's not re...
11 years agoDid you free up some memory resources before loading the PLL in Qsys? Or you can try increasing the required memory setting in Settings>IP Settings>Max Qsys memory usage> 1GB. By default, it is set to 500MB.
