20 years agoaltera timer hal overflow question ?
do altera hal timers work correct if the end of the system tick
variable range is reached ? Please check the following and tell me if I'm wrong. see files alt_tick.c, alt_alarm_start.c, /* * "_alt_nticks" is the number of system clock ticks that have elapsed since * reset. */ volatile alt_u32 _alt_nticks = 0; --> this will result in an overflow after about 49,71.. days if the system clock timer is set to 1ms, which is ok for a pc (normally shut off before 49 days), but an embedded system will normally run longer. what happens with the timers when an overflow condition exist ??? e.g. to simplify we use a range of 255 ticks and an periodic timer of 10 ticks. callbacks are run if (alarm->time <= _alt_nticks) is true so timer will run ticks 000 system starts ... 010 (10<=10)-> first callback (timer is rescheduled with alarmtime=alarmtime+10=20) ... 020 (20<=20)-> second callback (timer is rescheduled with alarmtime=alarmtime+10=30) ... ... ... 250 (250<=250)-->x' callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=4) 251 (4<=251)-->callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=14) 252 (14<=252)-->callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=24) 253 (24<=253)-->callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=34) 254 (34<=254)-->callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=44) 255 (44<=255)--> callback (timer is rescheduled with alarmtime=alarmtime+10 overflow will result in alarmtime=54) 000 (54<=000) is false ... 054 (54<=54) -> callback in the range of (tick_range - alarmtime) callbacks are executed every tick instead of alarmtime ticks, on alt_tick overflow, timer will be suspended for (alarmtime*alarmtime ticks). e.g. a periodic timer with 1000ms and a system timer tick of 1ms after 49,71 days the following will happen the timer will run 1000 times every 1ms just before _alt_nticks overruns, then it will need (1000*1000) ms = 1000sec = 16,66 minutes until the timer will start again. is this correct or I'm wrong ???3 Replies
Hi Fischer,
Which Nios II version are you looking at? I currently have Nios II 5.1, and in Nios II 5.1 there is a roll-over flag -for each alarm- that handles the wraparound of the timer. Although it has not the wraparound problem, as a general comment, the alarm implementation used by the HAL could be optimized: now it has an overall O(t*n) complexity, where t is the mean number of ticks of each alarm, and n is the number of alarms... If the alarm ticks are stored in an incremental way (like we do in the OSEK alarms implemented in ERIKA Enterprise), you can save some time when the numbre of alarms grows up... bye Paolo - Altera_Forum
Hi Paolo,
we currently use NIOS II 5.0, we did not upgrade to 5.1 because we just finished some projects and we already made some bad experience with update. in 5.0 the rollover flag does not exist, so I expect undefined behavior in all our projects. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thanks altera for the good information http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Altera_Forum
The system and time functions from newlibc don’t work as expected. Due to the limited range of _alt_nticks (32bit) the function clock() returns zero after 49 days.
Why is _alt_nticks not implemented as 64bit integer? Does nios support 64bit integer (long long)? Thanks for all information...
