20 years agoaltera timer hal overflow question ?
do altera hal timers work correct if the end of the system tick variable range is reached ? Please check the following and tell me if I'm wrong. see files alt_tick.c, alt_alarm_st...
20 years agoThe system and time functions from newlibc don’t work as expected. Due to the limited range of _alt_nticks (32bit) the function clock() returns zero after 49 days.
Why is _alt_nticks not implemented as 64bit integer? Does nios support 64bit integer (long long)? Thanks for all information...
