21 years agoaltera' SDRAM controller
I used altera's SDRAM controller to read data from my board SDRAM.
My PLD is the master, and it will access the SDRAM controller. But i find a very strange problem. I test the SDRAM controller, Write data to sdram, I write 400x32 bit(data bus is 32bit), It will spend 430 cycle, (almost one cycle one data). Read data from sdram. I read C00x32bit, But it spend e2d3 cycle!!!!!!(It means that 12 cycle , one data). The delay is too large. Does anyone used the sdram controller, do you have the same result ????? Thanks.2 Replies
Yes, read the other threads about this. For example this one:
nios sdram performance (http://www.niosforum.com/forum/index.php?act=st&f=2&t=629&hl=) You can click on Search and type "SDRAM controller" to find other threads. C - Altera_Forum
Now i find the problem in my design. Because i don't use the pipeline transfer feature of sdram controller.
Use the readdatavalid pin. I read the pipeline transfer(master read) feature of avalon spec. But i still some questions. 1 the spec don't tell me how to end a transfer. 2 becuase sdram controller will spend some cycle on refreshing . So , if i read data from sdram in each cycle. maybe the fifo of sdram controller will be full.
