20 years ago
alt_busy_sleep
Dear All,
My code need to call alt_busy_sleep(), but the compiler report the following error.
Linking TestCPP.elf...
obj/main.o(.gnu.linkonce.t._ZN13JaidTestClass18TestOSDBlockAdjustEv+0x18c): In function `JaidTestClass::TestOSDBlockAdjust()':
C:/altera/OSD_FINAL/JaidNiosOSD/software/TestCPP/TestClass/TestClass.hpp:352: undefined reference to `alt_busy_sleep(unsigned int)'
I have include the necessary header file in my code, # include "priv/alt_busy_sleep.h"
also I can find alt_busy_sleep.c in C:\altera\kits\nios2_51\components\altera_nios2\HAL\src.
Why the linker can't find alt_busy_sleep yet. Evenly I copy alt_busy_sleep.c to project folder, but the error still exist...
Anybody help...
Thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
    nios2_5.1
    quartusii_51_sp1_web_edition.exe
    somebody tell me that:
    Do you use C and C++ files in your project? You should declare the function alt_busy_sleep() is a C function if you use it in a C++ file.
    But I don&#39;t know how can I declare the function alt_busy_sleep() is a C function in C++ files.
    Also I need to understand why.
    Thanks for your reply....
    --- Quote Start ---
    originally posted by david_cai@Jul 6 2006, 10:56 AM
    dear all,
    my code need to call alt_busy_sleep(), but the compiler report the following error.
    linking testcpp.elf...
    obj/main.o(.gnu.linkonce.t._zn13jaidtestclass18testosdblockadjustev+0x18c): in function `jaidtestclass::testosdblockadjust()&#39;:
    c:/altera/osd_final/jaidniososd/software/testcpp/testclass/testclass.hpp:352: undefined reference to `alt_busy_sleep(unsigned int)&#39;
    i have include the necessary header file in my code, # include "priv/alt_busy_sleep.h"
    also i can find alt_busy_sleep.c in c:\altera\kits\nios2_51\components\altera_nios2\hal\src.
    why the linker can&#39;t find alt_busy_sleep yet. evenly i copy alt_busy_sleep.c to project folder, but the error still exist...
    anybody help...
    thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/laugh.gif
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16681)
    --- quote end ---
    --- Quote End ---
    Hi David_Cai!
    I had this type of error when I had q5.1 and nios 5.0!
    Later I have installed Nios 5.1 and error had not occired.
    Please give more specific information about your system
    version of Q and Nios http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    Dear All,
    I have solved this issue.
    The answer is :
    extern "C" unsigned int alt_busy_sleep (unsigned int us);
    But I still don&#39;t know why...
    Anybody help?
    David
    Hi David
    The compiler rules for C and C++ are some what differ. when you write any code in C and if you want to access that function or structure in C++ file then explicitly you have to tell to compiler and it will call that perticular function( or Build) as a C style rules and gives no error.
    At the same time you if you want to access C++ code in C file then also you have to define a Macro for that.
    Here i am passing you one link..Just go through this and get the detail answer.
    If you have any query then Ask me
    http://developers.sun.com/prodtech/cc/articles/mixing.html (http://developers.sun.com/prodtech/cc/articles/mixing.html)
    slsnios
    Thanks very much...
    I think that the basic reason is:
    The function name after compilation is different in C from that in C++. The declaration is necessary for both sides.
