20 years agoalt_busy_sleep
Dear All, My code need to call alt_busy_sleep(), but the compiler report the following error. Linking TestCPP.elf... obj/main.o(.gnu.linkonce.t._ZN13JaidTestClass18TestOSDBlockAdjust...
20 years agoHi David
The compiler rules for C and C++ are some what differ. when you write any code in C and if you want to access that function or structure in C++ file then explicitly you have to tell to compiler and it will call that perticular function( or Build) as a C style rules and gives no error. At the same time you if you want to access C++ code in C file then also you have to define a Macro for that. Here i am passing you one link..Just go through this and get the detail answer. If you have any query then Ask me http://developers.sun.com/prodtech/cc/articles/mixing.html (http://developers.sun.com/prodtech/cc/articles/mixing.html) Best Regards, slsnios
