13 years agoAgain: MicroC/OS-II with the external VIC
Hi guys, I am still fighting with some issues that happen when using the external VIC. Here is what I have done: Nios II/f CPU with exceptions enabled, running at 125 MHz from external SSRAM. ...
13 years agoi am also using VIC for my application and stuck in similar kind of problem ....only difference is that i have single external interrupt which come at 125us. could u provide u r sopc file for my Reference.
My application receive interrupt form external PIO and miss lot's of interrupt. if i increase the VIC clock frequency from ddr2_bot_auxhalf to ddr2_bot_auxfull my VIC work fine but System stop responding to PING request , as VIC suppose to receive some fix amount of interrupt (640X460) in a loop and it miss some of interrupt so loop could not complete for fix amount of interrupt , so it won't come out from loop and resultant it won't respond to PING request. so if you have any comment/suggestion on this issue please provide.
