3LionsCT's avatar
3LionsCT
11 months ago
Address Space?
Hi
I am confused about the address space requirements when using your own Avalon master in a custom module. (see attached)
Why do I have to use more address bits than I need when I only drive one module. It appears that  I have to add 2 extra bits to my address space for every module I go through to account for the interconnection fabric. This means that the address I generate has to be 28 bits instead of the 24 bits I need to address the RAM
I know it is probably something stupid I am doing here. What am I missing?
Thanks for the help
  • sstrell's avatar
    sstrell
    Also, you don't need to create custom arbitration logic.  The interconnect builds arbitration logic for you.
    • 3LionsCT's avatar
      3LionsCT
      I believe it is 32 bits. I've attached the address map.
      Could the extra two bits have anything to do with using a 32 bit address bus so the Address bus needs an extra two bits for the bye offsets?
      • ShengN_altera's avatar
        ShengN_altera
        May I know if the arbiter module is not used, the custom hdl min address width is?
