Address Space?
May i know what is your Nios V system address width?
I believe it is 32 bits. I've attached the address map.
Could the extra two bits have anything to do with using a 32 bit address bus so the Address bus needs an extra two bits for the bye offsets?
- ShengN_altera10 months ago
[DELETED]
May I know if the arbiter module is not used, the custom hdl min address width is?
- 3LionsCT10 months ago
The arbiter module is used. I attached a sketch of the system with the address widths. Basically I am trying to access a common sdram from both the Nios V and my own custom HDL
I mean if you don't use the arbiter module but straight connect both Nios V and custom HDL to sdram what happen to the minimum address width?
You can use platform designer arbitration logic https://docs.altera.com/r/docs/683609/25.1.1/quartus-prime-pro-edition-user-guide-platform-designer/arbitration
