15 years agoAdding Avalon-MM tristate bridge hangs the system
I have a perfectly working system using onchip RAM/ROM. Now I want to add interface to off-chip SRAM using Avalon-MM TriState Bridge. Problem is when I just add this component in SOPC, the resulting system (after re-creating BSP, recompiling etc.) hangs even when I am not trying to use the off-chip ram. By hangs I mean that my hello_world_small program does not output anything. All the i/f signal for the bridge seems to be OUT type, except the data, which i have left open for the time being. What am I doing wrong?
Thanks. Pratip1 Reply
Are you sure that your BSP settings don't use the offchip ram for anything? Check all the linker sections, and the settings for stack and heap.
