15 years agoAdding Avalon-MM tristate bridge hangs the system
I have a perfectly working system using onchip RAM/ROM. Now I want to add interface to off-chip SRAM using Avalon-MM TriState Bridge. Problem is when I just add this component in SOPC, the resulting ...
15 years agoAre you sure that your BSP settings don't use the offchip ram for anything? Check all the linker sections, and the settings for stack and heap.
