19 years agoadding a control signal to the SOPC
i need a single-bit control output from the NIOS. currently, i have created a new single-bit PIO. however, this output signal will not hold as a logic high. instead, it rises and falls with the clock signal. is there some "output" component or something from the NIOS that will hold the signal high until it is set low again? (it could be that there is another problem with my design...let me know)
1 Reply
Hi cryinlion85,
> this output signal will not hold as a logic high. instead, it rises and falls with the clock signal. This sounds like your pin assignments are incorrect ... i.e. you may have a few signals mapped to the wrong pins. Regards, --Scott
