19 years agoadding a control signal to the SOPC
i need a single-bit control output from the NIOS. currently, i have created a new single-bit PIO. however, this output signal will not hold as a logic high. instead, it rises and falls with the cl...
19 years agoHi cryinlion85,
> this output signal will not hold as a logic high. instead, it rises and falls with the clock signal. This sounds like your pin assignments are incorrect ... i.e. you may have a few signals mapped to the wrong pins. Regards, --Scott
