14 years agoaccess to every address of SDRAM
I have a problem with reading and writing data on SDRAM, I need to access every address of SDRAM, this is my C code written for Nios: # include <stdio.h> # include <io.h> # define BASE_SDR...
14 years agoActually the nios cpu always requests 32bit reads - and discards the unwanted bytes itself, rather than (also) asserting the relevant byte enable line(s).
If you have an 8bit slave, a 'bus width adapter' is used to convert the 32bit access into four 8bit ones. IIRC these copy over the byte enables from the original request - but don't skip the cycles that have no asserted byte enabled. These extra cycles show up as a measureable delay, especially when clock crossing bridge in included. They also cause much confusion when the bus master is the PCIe block - which always does 64bit slave accesses.
