21 years agoabout factory configuration hardware project
There is a method for restoring factory configuration data to safe section of Flash on 1S10 board,but there isn't any source project for hardware using QII and software code.
I want to know how the safe hardware image run programme. Can some body send this project to me? e-mail: [email protected] thank you!1 Reply
The factory hardware design is identical to the "Standard" design in almost every way; the only difference is that the "factory" design has its CPU reset address set to a special locatio of flash where the factory-web-server is programmed in. The factory web server is very similar to the 'web server' software example design.
