21 years agoabout factory configuration hardware project
There is a method for restoring factory configuration data to safe section of Flash on 1S10 board,but there isn't any source project for hardware using QII and software code. I want to know h...
21 years agoThe factory hardware design is identical to the "Standard" design in almost every way; the only difference is that the "factory" design has its CPU reset address set to a special locatio of flash where the factory-web-server is programmed in. The factory web server is very similar to the 'web server' software example design.
