21 years agoA Strange Address
When I burn a hardware imge to my falsh, following info displays in the console:
..............................................................................# Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=standard.flash --sof=$SOPC_KIT_NIOS2/components/altera_nios_dev_board_cyclone_1c20/system/altera_nios_dev_board_cyclone_1c20.sof --base=0x00800000 .............................................................................. I have checked in the SOPC Builder, the address 0x00800000~0x00ffffff is not allocated to any device, but in the info it says "--base=0x00800000". Why? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif2 Replies
When the flash programmer is downloading an image to flash, it first puts it's own Nios core on the FPGA (in this case altera_nios_dev_board_cyclone_1c20.sof). The address listed with the --base parameter is the base address of the flash device within this core and has nothing to do with the base address in your own core.
Dennis Scott Microtronix Datacom Ltd. - Altera_Forum
Hi, Dennis.
Thanks for your help. In the example of standard, SOPC Builder assign the base addresses automatically, but why doesn't it asign the address of 0x00800000~0x0FFFFFF to a device? Does it have something to do with the base address (0x00800000) of CFI in the <altera_nios_dev_board_cyclone_1c20/system/altera_nios_dev_board_cyclone_1c20.sof>?
