15 years ago
10.1 Flash Programmer Error code: 4
I have a new design containing two Cyclone III (3C40's), each with a 256Mbit Numonyx P33 flash (65nm version) that fail (they both fail the same way) with the Nios II flash programmer. It seems the programmer reads the CFI query table info correctly but gives Error code: 4 (see below). I have tried manually to read/write/erase the device and it seems to work perfectly fine - but the GUI failure persists. I did notice that the blocks appear locked (not in lock-down mode, but just block-lock), which I know in the past the programmer takes care of doing the unlocking, etc... in any case I did try to unlock them manually and retry - no luck.
I've seen a couple other posts on this (specifically one with Error code: 4) with no resolution - does anyone know what could be wrong and potential work-arounds?
thank you
OUTPUT FROM PROGRAMMER:
Info: Aug 22, 2011 8:13:29 AM - (FINE) bin2flash: Starting
Info: Aug 22, 2011 8:13:29 AM - (INFO) bin2flash: args = --input=MyPath/testfile.bin --output=MyPath/flash/testfile_NOR_flash_0.flash --location=0x0 --verbose
Info: Aug 22, 2011 8:13:29 AM - (FINE) bin2flash: Done
Info: Using cable "USB-Blaster [USB-0]", device 3, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Found CFI table in 16 bit mode
Info: Raw CFI query table read from device:
Info: 0: 89 00 22 89 01 00 FF FF 89 00 4F F9 04 00 FF FF ..".......O.....
Info: 10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 20: 51 00 52 00 59 00 01 00 00 00 0A 00 01 00 00 00 Q.R.Y...........
Info: 30: 00 00 00 00 00 00 23 00 36 00 85 00 95 00 09 00 ......#.6.......
Info: 40: 0A 00 0A 00 00 00 01 00 02 00 02 00 00 00 19 00 ................
Info: CFI query table read from device:
Info: 10: 51 52 59 01 00 0A 01 00 00 00 00 23 36 85 95 09 QRY........#6...
Info: 20: 0A 0A 00 01 02 02 00 19 01 00 0A 00 02 03 00 80 ................
Info: 30: 00 FE 00 00 02 00 00 00 00 FF FF FF FF FF FF FF ................
Info: 40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: CFI extended table read from device:
Info: 0: 50 52 49 31 35 E6 01 00 00 01 03 00 30 90 02 80 PRI15.......0...
Info: 10: 00 03 03 89 00 00 00 00 00 00 10 00 04 05 04 01 ................
Info: Read autoselect code 0089-8922 (in 16 bit mode)
Info: No CFI override data for [FLASH-0089-8922]
Info: Target timeout loop runs 2227010 times/s
Info: Timeout set to 2281 loops
Info: Device size is 32MByte
Info: Erase regions are:
Info: offset 0: 4 x 32K
Info: offset 20000: 255 x 128K
Info: Device supports Intel style programming algorithm
Info: Multi-byte programming with 1024 byte buffer
Info: Sector erase timeout is 4s
Info: Word program timeout is 1ms
Info: Buffer program timeout is 4ms
Info:
Info: : Checksumming existing contents
Info: 00000000 : Checksum failed - needs program
Info: 00008000 : Checksum failed - needs program
Info: 00010000 : Checksum failed - needs program
Info: 00018000 : Checksum failed - needs program
Info: 00020000 : Checksum failed - needs program
Info: 00040000 : Checksum failed - needs program
Info: 00060000 : Checksum failed - needs program
Info:
Info: Checksums took 0.1s
Info: Erase not required
Info:
Info: 00000000 ( 0%): Programming
Info: Write address 0x12000000 <= 0x0090
Info: Read address 0x12000004 => 0x0001
Info: Write address 0x12000000 <= 0x60
Info: Write address 0x12000000 <= 0xD0
Info: Read address 0x12000000 => 0xB0
Info: Write address 0x12000000 <= 0x50
Info: Write address 0x12000000 <= 0xFF
Info:
Info: Program failed at offset 0
Info: Leaving target processor paused
Error: Error code: 4 for command: bin/nios2-flash-programmer "MyPath/flash/testfile_NOR_flash_0.flash" --base=0x12000000 --accept-bad-sysid --device=3 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose
    Did you ever get an answer to what Error Code 4 is? I am getting the same error code from the nios flash programmer but so far have not found any information on it.
    I am getting the same error code from the nios flash programmer.
