.elf of updated build not downloading to Nios V from RiscFree
- 1 year ago
Thank You for Your reply.
Things has made a weird turn to the better..
I tried to recreate the situation before I did the edits in bsp_editor I mentioned in my previous post.
I started bsp_editor, opened the settings.bsp-file, checked enable_alt_load and enable_alt_load_copy_rwdata and generated bsp_settings again.
However, I did not get back to my previous situation. I was still in a situation where a reset would freeze the niosV, only a new run from RiscFree would get it running again.
To get out of this situation, I tried to generate a new bsp rather than editing the old one.
Voila:, everything works. If I edit the hello.c file, the newest version runs on then NIOS.
I think I am now in the situation where the old proverb "If it aint broken, dont fix it" applies.
We can consider this case closed.
Unfortunately, when I regenerated the new setting.bsp the old one was overwritten, and it it thus not possible to compare working and non-working versions.
Thank You again for Your help.
Best regards
Eivind
Hi
When running downloading the elf in RiscFree did you by chance selected the old elf file in the configuration settings below:
Jingyang, Teh
- Eivind1 year ago
Thanks for the reply.
There is only one .elf file in the system, the old one is overwritten during compile. I have verified that the .elf-file on the PC is in fact the newest version.
It makes no difference whether I have selected "use project binary" or "use file" and link to the correct file. Somehow then new .elf seems to not download to the FPGA.
Eivind
