10 years agoXAUI Tx lane reversal
Hi everyone, I designed a board with Arria V GX on it. I have mistakenly reversed (In relation to Rx) the XAUI Tx lanes on my new board. The compilation fails for the current pin layout. Whe...
10 years agoHi,
Have you tried the assignment? You can find this in the Transceiver PHY IP User Guide. Example 7-1 shows how to remove the restriction on logical lane 0 channel assignment in Stratix V devices by redefining the pma_bonding_master parameter using the Quartus II Assignment Editor. In this example, the pma_bonding_master was originally assigned to physical channel 1. (The original assignment could also have been to physical channel 4.) The to parameter reassigns the pma_bonding_master to the XAUI instance name shown in quotation marks. You must substitute the instance name from your design for the instance name shown in quotation marks Example 7-1: Overriding Logical Lane 0 Channel Assignment Restrictions in Stratix V Devices set_parameter -name pma_bonding_master "\"1\"" -to "<xaui instance name>|sv_xcvr_xaui:alt_xaui_phy|sv_xcvr_low_latency_phy_nr: alt_pma_0|sv_xcvr_custom_native:sv_xcvr_custom_inst|sv_xcvr_native: gen.sv_xcvr_native_insts[0].gen_bonded_group.sv_xcvr_native_inst" Swapping parallel data bus wouldn't work because the XAUI PHY IP expects start-of-packet symbols come to Lane 0.
