12 years agoXAUI core simulation for Cyclone V
I'm simulating in Modelsim XAUI Phi core generated by Megawizard for Cyclone V. I use QII 13.0.1. This is a stand-alone simulation (core only) The problems: 1. No stimulus in the simulation files, generated by Megawizard, only "bare" XAUI core called for simulation. 2. When I added stimulus generation module, signal phy_mgmt_waitrequest, set to 1'b0 by reset, set to 1'bZ in every phy_mgmt bus read/write attempt 3. channel 3 of XAUI output becoming undefined soon after simulation started. Anybody have the same problems or may be give any suggestions, advices, solutions??? Thanks.1 Reply
Thanks for all! Problem is solved, solution is here: http://yadi.sk/d/s2kbxtjtefkoc
