17 years agowrong FFT output-data?!
I hope somebody can help me. First my configuration: Cyclone III Starter Kit FFT v8.0 with 1024 points burst 14 bit resolution 32MHz clock 2MHz output clock (after FIFO) Ok, how should I start. I've got two problems: 1. the reset! When do I have to do a reset? Once after programming the device, e.g. pushing a button? Or after each FFT run? 2. the scaling! I read many facts about that, but I think I didn't get it right now. At the FFT User Guide I read the implementation and I don't know, if I understood that right: example: 14 bit full range, 4 bit (1001) word, shifting 4 times result: 111111 1001 0000 100000 1001 0000 000000 1001 0000 Which of these results is the correct one? I programmed my device and put a sinus on the ADC-board. From here it goes onto the FPGA, into the FFT-real-input. My results look like the attached picture. The MSB are always "1" or "0" at the same time :confused: I tried so much and I don't know what to do more. I also attached my "shifter.vhd"-file, which handles the scaling. Thanks for your help! Lars :(No RepliesBe the first to reply
