15 years agowrong data through IFFT, FFT
Hi everyone, I use altera fft ip core 9.0, and let my data go through 1024 ifft - GI - GI_remover - 1024 fft, but i did not get the origin data back(not the scaling problem, the data is totall...
15 years agoI would recommend that you check your data representation. Ensure that your input data is in the format expected by the FFT component. If your data's time samples span -N/2-N/2, but your fft is configured for natural order, you will have a problem in your output. Since you are recieving the SOP and EOP from the source interface, the issue is probably just a configuration issue.
BTW, what type of signal/data are you analyzing? What is the bandwidth of the signal? Give me a little bit more information about your signal and the configuration and I may be able to provide some additional help. I just spent 2 weeks trying to the FFT in my system working and I finally figured out where all(hopefully) of the pitfalls are.
