15 years agoWhy won't my FIFO Fill?
Hello, In my SOPC design I have a Dual Clock FIFO fed by an SGDMA clocked at 80Mhz (no burst) and feeding a video pipeline clocked at 20Mhz. My SDRAM is 8bit and the SGDMA is clocking ou...
15 years agoIf you don't use bursts, it could require more clock cycles to fetch the data from the SDRAM, meaning that it won't be able to fill the FIFO at 40MB/s
