16 years agoWhite Noise Spectrum
I have use a simple LFSR to generare random number to generate white noise. Set of random number are pass through to FFT(power in db vs freq). However, the freq response is increasing at low freq. Th...
16 years ago1. In other words, the normalized range is -1..+1, and the average should be around zero?
3. Magnitude, this is in my understanding sqrt(real² + imaginary²), should be already positive? 4+5. 20*log10(magnitude) should give the same result? --- Quote Start --- Any problem with this step above? --- Quote End --- None, except this: How do you get a result range of -360..-180, and why do you think, -360 is larger than -180 ("increasing")?
