16 years agoWhere's the Avalon Microsequencer???
I finally found a good app for the Microsequencer. But I don't see it in the SOPC Builder v9.1, nor does google return non-stale documentation on it.
Did Altera remove it from SOPC Builder??? :confused: -- Pete4 Replies
I believe I know the guy who wrote it. Let me ask him about it. Alternatively, you can try copying it over to the \altera\91\ip\altera\sopc_builder_components directory from an old install.
Jake - Altera_Forum
Ok I tracked down an instantiated version of the uSequencer from an old project. I added some stuff to it (code update port) and gave it a GUI so it's risen from the ashes!
I originally tried to install the version I had but it said I required Quartus v3.0 or later ... I have Quartus v9.1! Anyways, the .ptf file would have probably been completely useless in the latest SOPC Builder. Thanks for your efforts though! -- Pete - Altera_Forum
I spoke to the designer. He said the component needed to be updated for 9.1. He was going to look into it. Sounds like you got it figured out.
Jake - Altera_Forum
Hi all,
which version of old Quartus do i need to install, when i want to use Avalon microsequencer? I tried to use install from http://www.alterawiki.com/wiki/avalon_microsequencer but it told me, that i need to have Quartus SOPC Builder 3.0 and later. I have Quartus 13 with QSys and Quartus 12 with SOPC Builder, but it doesnt work. Thank you very much. Honza Naceradsky
