15 years agoWhere to connect the user app ? pici-e
on page 2.17 of the UG, it states: replace the endpoint application layer with your own design. I expected to find a module with the Avalon MM signals, where I can connect my design, I sp...
15 years agoIf you take a look at the Qsys design,
http://www/support/refdesigns/ip/interface/ref-pciexpress-ddr3-sdram.html It is easy to understand. You just need to connect your own design in the Qsys. The example only has few blocks, so it will help you understand more. You can chose either connecting your logic to bar or the DMA.
