CheepinC_altera
1 month agoHi,
Sorry for the delay. The following are the archive for Agilex F-Tile designs that I could locate. Can you help to check out. Thank you.
1. Multi-Prbs Generators and Checkers
- (28/04/2021) Collection of Multi-Prbs Generators and Verifiers used in various transceiver demo's with different bit widths: 32-bit, 64-bit, 128-bit, and 256-bit. Includes test bench as well.
2. Supporting documentation for the F-tile Demo Designs
- Soft PRBS Demo designs (with/without RSFEC)
- agilex-f-tile-demo-designs.pdf Updated (03/02/2022)
- Superlite II designs
- agilex-f-tile-superlite-ii-demo-designs.pdf Updated (09/02/2022)
- Superlite IV designs
- agilex-f-tile-superlite-iv-demo-designs.pdf Updated (18/02/2022)
3. Description of all F-tile Demo Designs (Excel file)
- Updated (15/02/2022)
- description-of-designs.xlsx (V1.6)
4. Library of C-functions for F-tile transceivers using AVMM Interfaces
- Updated (28/01/2022)
- Complete library of C-functions/drivers for F-tile
- f-tile-software.zip (V1.9)
5. Script with useful procedures for use in the system console with Agilex F-tile
- New (12/08/2022)
- Functions to be used with F-tile PHY-Direct/FEC-Direct designs/F-tile Ethernet Hard IP designs (controlling loopbacks, showing PMA settings, performing EHM, setting Media mode to VSR/Optics etc.). Requires NDME to be enabled. Supports both FGT and FHT.
- ttk-helper-ftile.tcl (V1.0)
6. Soft PRBS with RSFEC Demo Designs
Intel Agilex® device I-Series PCIe development kit
- NEW (04/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 1x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 2x200G Aggregate mode using FGT transceivers connected to QSFPDD1
- NEW (11/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4 channel 25.78125 Gbps soft PRBS test design with RSFEC (528,514) in 2x100G Aggregate mode using FGT transceivers connected to QSFPDD0 and QSFPDD1
- Updated (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 1x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD1
- NEW (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 200G Aggregate mode using FGT transceivers connected to QSFPDD's
- Updated (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FGT transceivers connected to QSFPDD's + dynamically reconfigurable internal noise.
- NEW (11/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 3x4x1 channel PAM4 53.125 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FGT transceivers connected to QSFPDD's
- (13/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel NRZ 25.7815 Gbps soft PRBS test design with RSFEC (528,514) Fractured mode using FGT transceivers connected to QSFPDD's
Intel Agilex® device I-Series SI/SOC Board
- NEW (06/12/2021) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): 2x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD0 and QSFPDD1
- NEW (06/12/2021) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile device): 1x8 channel 53Gbps PAM4 soft PRBS test design with KPFEC (544,514) in 400G Aggregate mode using FGT transceivers connected to QSFPDD0
Intel Agilex® device I-Series HS Demo Board
- (17/09/2021) Intel Agilex® device I-Series HS Demo Board (ES Version): 2x4 channel PAM4 53.125 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FGT transceivers connected to FMC+
- Updated (28/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel PAM4 106 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FHT transceivers connected to OSFP800
- NEW (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel NRZ 53.125 Gbps soft PRBS test design with KPFEC (544,514) Fractured mode using FHT transceivers connected to OSFP800
7. Soft PRBS Demo Designs (no FEC)
- NEW (02/02/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): 2x8x1 channel 53Gbps PAM4 soft PRBS test design using FGT transceivers connected to QSFPDD0 and QSFPDD1
- Updated (31/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's with dynamically reconfigurable internal noise logic.
- (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel NRZ 25.78125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
- agilex-pcie-devkit-prbs-2x4x1ch-ftile-26gbps.zip (21.3 B170)
- (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 2x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
- agilex-pcie-devkit-prbs-2x4x1ch-ftile-53gbps.zip (21.3 B170)
- (08/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 3x4x1 channel PAM4 53.125 Gbps soft PRBS test design using FGT transceivers connected to QSFPDD's
- agilex-pcie-devkit-prbs-3x4x1ch-ftile-53gbps.zip (21.3 B170)
- (20/09/2021) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x4 channel NRZ 25.78125 Gbps soft PRBS test design using FGT transceivers connected to FMC+
- Updated (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel PAM4 53.125 Gbps soft PRBS test design using FHT transceivers connected to OSFP800
- NEW (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel NRZ 53.125 Gbps soft PRBS test design using FHT transceivers connected to OSFP800
- Updated (26/01/2022) Intel Agilex® device I-Series HS Demo Board (ES Version): 4x1 channel PAM4 106 Gbps soft PRBS test design using FHT transceivers connected to OSFP800
8. Superlite II V4 (with/without KR FEC)
- New (10/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite II V4 design using 2 times 4 lanes at 25.78125 Gbps to transport 100 Gbps of raw data.
- NEW (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite II V4 with soft KR-FEC Demo design using 2 times 4 lanes at 10.3125 Gbps to transport 40 Gbps of raw data
- agilex-pcie-devkit-superliteii-v4-soft-krfec-ftile-fgt-2x4-lanes.zip (21.4, can be programmed using 21.3)
- Updated (10/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite II V4 design using 2 times 4 lanes at 10.3125 Gbps to transport 40 Gbps of raw data.
9. Superlite IV (RSFEC)
- NEW (18/01/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): Superlite IV design using 4 instances (one per F-Tile) of 2 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 8 lanes at 53.125 Gbps to transport 400 Gbps of raw data (transparent transmission of a 1,024-bit bus), total bandwidth = 4x400Gbps = 1.6 Tbps
- NEW (18/01/2022) Intel Agilex® device I-Series SI/SOC Board (ES Version) (4 F-tile devices): Superlite IV design using 4 instances (one per F-Tile) of 3 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 12 lanes at 53.125 Gbps to transport 600 Gbps of raw data (transparent transmission of a 1,536-bit bus), total bandwidth = 4x600Gbps = 2.4 Tbps
- NEW (26/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 4 instances of 1 PHY direct IP configured in 100Gbps with KPFEC, bonded across 2 lanes at 53.125 Gbps to transport 100 Gbps of raw data (transparent transmission of a 256-bit bus), total bandwidth = 4x100Gbps = 400 Gbps.
- NEW (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 3 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 12 lanes at 53.125 Gbps to transport 600 Gbps of raw data (transparent transmission of a 1,536-bit bus)
- Updated (18/01/2022) Intel Agilex® device I-Series PCIe development kit (ES Version): Superlite IV design using 2 times a PHY direct IP configured in 200Gbps with KPFEC, bonded across 8 lanes at 53.125 Gbps to transport 400 Gbps of raw data (transparent transmission of a 1,024-bit bus)
10. 400GbE
- (8/10/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 400GbE (400G-8) Example Demo design using QSFPDD1
- (8/10/2021) Intel Agilex® device I-Series HS Demo Board (ES Version): 400GbE (400G-4) Demo design using OSFP800
- agilex-hs-demo-400gbe-4-fht-example-design.zip (21.3 B170)
11. 100GbE
- NEW (30/11/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 100GbE (100G-4) with RSFEC(528,514) 4x25.78125 Gbps Example Demo design using QSFPDD1
12. 25GbE
- NEW (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 25GbE (25G-1) with RSFEC(528,514), Single lane Example Demo design using QSFPDD1
13. 10GbE
- NEW (06/12/2021) Intel Agilex® device I-Series PCIe development kit (ES Version): 10GbE (10G-1), Single lane Example Demo design using QSFPDD1
