17 years agowhen i tried to import the hdl file to simulink, i got the following error message
Info: Quartus II Analysis & Synthesis was successful. 0 errors, 0 warnings Info: Peak virtual memory: 159 megabytes Info: Processing ended: Sat Apr 25 19:55:03 2009 Info: Elapsed t...
17 years agosorry. The simulation without HDL import blocks works well.
I copied the missing files "libmex.dll libmx.dll dwmapi.dll" to the directory "..\dsp_builder\bin" and complied the module again. This time, the message box said " Error generating simulation model. DSP Builder Fatal Error: uart: Unable to resolve name 'wrn' as a wire or I/O" Is there anything wrong with the verilog source code? I download the code from website and it can be synthetized successfully in Quartus II.
