17 years agowhen i tried to import the hdl file to simulink, i got the following error message
Info: Quartus II Analysis & Synthesis was successful. 0 errors, 0 warnings Info: Peak virtual memory: 159 megabytes Info: Processing ended: Sat Apr 25 19:55:03 2009 Info: Elapsed t...
17 years agoIt means that it can't find the dependencies for alt_dpsbuilder_mAltr_PvoIp.dll. This would usually mean that you were missing files on your computer or your installation was incomplete.
What version of DSP Builder are you using? What version of Windows are you using? Another thing to try is download "depends" from http://www.dependencywalker.com/ (http://www.dependencywalker.com/). Then run it on the DLL in e:\soft\quartus\quartus\dsp_builder\bin. That should tell you what you are missing.
