17 years agoWhat is the secret to how the VIP Scaler works, and can it handle 4:2:2 video?
We are currently working on a system which is fairly complex. We thought we could save some time by utilizing Altera's VIP Suite for decimation and interpolation (yuk, yuk). We are using custom fil...
17 years ago --- Quote Start --- I'm not an Altera employee. However, I have been using the tools for quite some time now (since about 4.1). If there is anything that I or other members of the forum can help you with to make your design successful, don't hesitate to ask. I know there are several companies using the VIP suite in their products (myself included). I'm sure some of them can provide help should you continue to battle with it. Jake --- Quote End --- I am using vip suite 9.0 and quartus 9.0 for out new project. I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following issues 1.I did not found any where a detailed procedure for giving the run time parameters.The vip suite pdf is very vague not detailed in this issue. 2.I could not able to generate the frames using the run time control i could only process single frame that too not correctly the parameters i am giving are output width 64 and height 32 using the registers and input width and height as 32x32 using the control packet but the problem is the core is not discarding the extra data if i gave more than 1024 pixels and the output is same size as the input please help me regarding these issues Regards ysc
