14 years agoWhat is the IP core?
Hello.
I would like to know, what is the IP core that is named “10G GFEC RS(255, 239) MegaCore”. I have not find this core by the search. I’ve found only such IP core description by Google and Altera search: http://www.altera.com/literature/po/ss-rsgfec.pdf (http://www.altera.com/literature/po/ss-rsgfec.pdf) Are they the same? If yes (or no), how can I get the detailed description of “10G GFEC RS(255, 239) MegaCore”? Thank you in advance for answers.4 Replies
I think its a FEC(forward error correction) core with ReedSolomon Decoder. This core is integreted with 10G ethernet (PCS)
Thank you for answer.
Of course, this is FEC, RS(255, 239). I don't sure that it is integrated with 10G Ethernet, because there are several 10G interfaces with and without FEC support... So I would like to receive exact description of the core. - Altera_Forum
is it the Reed Solomon II core?
http://www.altera.com/products/ip/dsp/error_detection_correction/m-alt-rs-encoder-decoder-ii.html - Altera_Forum
Reed Solomon II is a configurable core.
RS(255, 239) means that it is fixed core for encoding/decoding Reed Solomon (255, 239) codes.
