10 years agoVIP video monitor: expected number of pixels mismatch for Bitec HDMI input
Good evening. I'm sending video data from a Bitec HDMI RX core via a clocked video input to an Avalon-ST video monitor, in order to check if my HDMI input is OK. HDMI input core seems to work o...
10 years agoThank you, that was the solution. After inserting the frame buffer after CVI II, things started working without problem. It is interesting that I wasn't able to get the system working with a FIFO only, whatever I tried. Even with only slightly different pixel clocks for input and output, CVI shut down with overflow immediately.
