10 years agoVIP video monitor: expected number of pixels mismatch for Bitec HDMI input
Good evening. I'm sending video data from a Bitec HDMI RX core via a clocked video input to an Avalon-ST video monitor, in order to check if my HDMI input is OK. HDMI input core seems to work o...
10 years agoIf input and output of your system have different bitrate you should use frame buffer with frame rate conversion(it is one of frame rate conversion method). You can insert it in any place of your video path. Monitor does not affect the bandwidth
