9 years agoVIP Suite (CVI, Frame Buffer, CVO) Vertical Ancillary packet problem
I need help on how to successfully transport the Vertical Ancillary (VANC) packet from with the configuration below. ----(embedded video sync)---> CVI ---> Frame Buffer ---> CVO ----(embedded video sync)----> The input video format is 1080i60, Vertical ancillary packet at lines 19 and 20 for Field 0 and lines 582 and 583 for Field 1. CVI setting : Extract ancillary packet (checked) Frame Buffer setting: Set the value of non-video packet handling setting to maximum. CVO setting : set the appropriate ancillary insertion lines The problem is that all the vertical ancillary packet has been concatenated in line 19 of Field 0 as seen on the output of CVO. When I tried to simulate using a smaller video size (i.e. 128x128) and set the ancillary line for Field 1 to the appropriate line number for 128x128 video size, I have noticed that cause of the concatenation is from the Frame Buffer. I am using Quartus 14.1. Does anyone experienced this problem? Thank you. ZeahrNo RepliesBe the first to reply
