14 years agoVIP suite - how can I make my Y channel into 3xY in parallel in SOPC ?
hi, In my design I want to mix two streams with the alpha blending mixer. One stream, the background layer is 800x600 represented in RGB, three color planes in parallel. The oth...
14 years agohi again,
I'm clocking the camera stream into the SOPC system with a 27MHz clock while the system itself is using a 40MHz clock for the VIP chain, so I probable wont be able to solve this using your initial suggestion of triplication. Also, woudn't I have to change the control data packet information if I was to change the width of the VIP frame from 640 pixels to 640 X 3 pixels inorder to get the Y_10, Y_10, Y_10, Y_11, Y_11, Y_11..sequence ? I'm not sure if this is the right solution, but what would happen if I create a custom module that receives the camera stream from a source(deinterlacer) and place the 8bit Y values in a 24 bit signal(23..16)(15..8)(7..0) which is then streamed along with the valid, sop, eop signals to the alpha blending mixer (sink) ? Would this create an missmatch in the control data packet ?
